Choose your country or region
Italian
Swedish
Dutch
Грузия
Should You Buy a Wind Turbine for Your Home?
With rising electricity costs, many UK homeowners are exploring renewable energy options to save money and reduce their carbon footprint. While solar panels dominate the conversation, home wind turbines are gaining attention as a viable complement or sometimes an alternative to solar. While they can generate clean energy for homes, are they worth the investment?
Let’s explore how they work, their benefits, costs, and key considerations to help you decide if they’re right for you.
How Does a Home Wind Turbine Work?
With ever-rising electricity costs in the UK, off-grid power solutions like wind turbines are gaining popularity. Home wind turbines work much the same as commercial models that produce a third of our grid power but on a smaller scale. When the wind blows, it pushes on the blades, making them spin, rotating a shaft inside the turbine connected to a generator that produces direct current (DC) electricity.
The DC power goes into a home battery system or an inverter. The inverter converts the DC electricity into the alternating current (AC) that most homes and appliances use.
Types of Home Wind Turbine
Roof-Mounted Wind Turbines
Roof-mounted turbines are compact models for rooftop installations in rural and suburban areas that don’t have enough land for a standalone system. Their small size means they only generate between 1 and 2kW of electricity.
Standalone Wind Turbines
Standalone systems are larger and come in capacities between 1.5 and 10kW. They consist of a turbine mounted on a tall pole to achieve maximum height. Since they’re much larger, they require ample open space, like a big field or on top of a hill, so they only work in rural areas.
What Are the Advantages and Disadvantages of Wind Turbines for Powering Your Home?
Advantages
  • About 40% of the wind energy in Europe blows over the UK, making it an abundant natural resource.
  • They produce electricity using a renewable energy source that produces zero carbon emissions.
  • They’ll help reduce your monthly electricity bills. With a sizable standalone system, you could generate enough to supply your entire household and potentially generate money by selling excess energy through the Smart Export Guarantee (SEG).
  • They can look aesthetically pleasing depending on the model and installation.
  • Wind turbines can add value to your home.
Disadvantages
  • They tend to be much more expensive than solar panel installations.
  • They’re unsuitable for urban areas, those with insufficient space, or areas with only a little breeze.
Factors to Consider Before Investing in a Wind Turbine for Your Home
Location
They require a location with lots of open space, especially standalone models. Also, those in conservation, heritage, or other protected areas will need permission to install them.
Wind Speed
These systems aren’t recommended in areas with average speeds of less than 5m/s. You can look up your average speeds on the Met Office website for an estimate. You can also invest in an anemometer to directly measure your local speeds for a more accurate figure. It’s a good idea to monitor speeds throughout the year to understand seasonal variations.
Planning Permission
Unlike solar panels, which seldom require planning permission, turbines often require permission.
In England, planning permission isn’t required if there are no other turbines or air source heat pumps on your property, the bottom of the blades are at least 5 metres off the ground, and you’re not in a Conservation Area, World Heritage site, or the grounds of a listed building.
For roof-mounted systems, the property must be detached, the top of the blades must be no more than 3m above the top of the property or 15m above the ground, and they must be located 5m from the property edge. For standalone systems, the top of the turbine must be no more than 11.1m above the ground and at least 1.1 times its height away from the property edge.
In Scotland, all roof-mounted systems require planning permission. However, this isn’t required for pole-mounted systems if it’s the only turbine on the property, is located more than 100 metres from the property boundary, and is not located in a Conservation Area, World Heritage site, area of scientific interest, or within the grounds of a listed building.
Finally, planning permission is always required to install any turbine system in Wales and Northern Ireland.
What Size Wind Turbine Do You Need to Power Your Home?
How big a system you need depends on how much electricity you use. According to Ofgem, UK residents consume about 2,700kWh of electricity annually for a 2-3 bedroom home.
Since wind is extremely variable throughout the year, estimating output is challenging. Still, a pole-mounted 1.5kW turbine could produce about 2,600kWh yearly, while a 10kW system would generate roughly 10,000kWh. It means a small pole-mounted system would easily power a small house but not a large house.
To get a more accurate idea, you must look at your power bills to determine your electricity consumption and use an anemometer to measure your speeds accurately. Then, you can estimate your output based on how efficient the manufacturer says their model is.
No matter what system size you get, optimising it for maximum efficiency and usability is essential. Just like using home batteries with solar energy, batteries are essential to store the energy you produce during windy conditions so you can still use it when it isn’t windy.
TheEcoFlow PowerOcean (Three-Phase) and the EcoFlow PowerOcean (Single-Phase) battery systems are perfect home battery solutions. They start at 5kW of capacity, which can be increased to 45kW with additional batteries. They also have an IP65 dust-proof and waterproof rating, so you can install them outside your home.
How Much Does a Home Wind Turbine Cost?
The cost varies widely with the model, manufacturer, size, and installation. Still, the average cost of a 0.5kW to 2.5kW roof-mounted turbine is about £2,000. Since they don’t generate much electricity, it could take a long time to get a return on your investment.
Standalone systems generate a lot more power but also cost a lot more. On average, a 5kW standalone turbine could cost between £30,000 and £40,000, including planning permission, site preparation, and connection to the electrical grid.
Is It Worth Getting a Home Wind Turbine?
Home turbines are expensive, but they’re growing in popularity. So, those prices may drop in the future as more people start installing them. If you have the space and sufficient breeze, they’re still a good choice for those working towards net zero and energy independence, either on their own or alongside solar installations.
When you use an energy management system like the EcoFlow PowerInsight, you can monitor your energy production and consumption to maximise your savings further. You can also use it to monitor the EcoFlow Power Heat. This residential air-to-water heat pump can be run on solar and uses electricity to bring ambient air heat energy into your house.
Another energy-saving product is the EcoFlow PowerGlow, which uses solar energy to heat water for household use and in-floor heating. It can be integrated with the EcoFlow PowerHeat and EcoFlow PowerOcean to maximise efficiency. In fact, you can achieve complete energy independence when you combine your renewable energy systems with an EcoFlow PowerOcean (Single-Phase) battery system.
  • How Big of a Wind Turbine Do You Need to Power a House?
    The size of the wind turbine you need depends on how much electricity your household uses. For instance, a pole-mounted 1.5kW turbine could produce about 2,600kW annually. The average 2-3 bedroom UK home uses about 2,700kWh per year. So, you must consider the output and your energy consumption.
Home turbines are a renewable alternative for generating electricity, especially in the UK, where wind is abundant. While the initial investment can be high, they offer long-term savings, reduced reliance on the grid, and the opportunity to lower our carbon footprint. However, their feasibility depends on wind speed, space, and planning permissions.
If you have the space and the right conditions, a home turbine—especially when paired with a home battery system like EcoFlow PowerOcean (Three-Phase) or the EcoFlow PowerOcean (Single-Phase)—can be an excellent addition to your energy strategy, helping you maximise efficiency and achieve energy independence.
EcoFlow offers innovative home battery storage solutions for homeowners seeking to optimize electricity consumption, cut costs, and achieve independence from the National Grid. Since 2017, EcoFlow’s home battery storage and solar generator solutions have been trusted by households in over 85 countries worldwide. EcoFlow's industry-leading home battery technology is designed to efficiently store electricity generated from solar energy and other sources to attain energy security and eliminate peak billing tariffs.
