Choose your country or region
Italian
Swedish
Dutch
Грузия
PowerOcean
Power That Comes With Safety​
Home Energy Storage System
Become Our Partner
Explore Our Battery Technology
Smarter BMS Longer Battery Life
7-Second Fire Prevention Module
Dual-LayerElectric Insulation
Extreme Weather Ready -20°C to 50°C
40,000N Impact Resistance
Integrated Battery Management System (BMS)
PowerOcean’s advanced BMS solutions optimise battery performance, extend lifespan, and reduce failure rates. This system ensures safe and efficient operation throughout the battery’s entire lifecycle.
20%longer lifespan*
15year warranty
50%lower battery pack failure rate*
*Theoretical values are based on testing in EcoFlow's internal laboratories under specific conditions. Actual performance may vary slightly due to differences in products, software versions, usage conditions, and environmental factors.
What can an integrated Battery Management System do?​
Battery Performance Analysis
Monitors battery temperature, voltage, and current data in real-time, analysing key metrics such as SOC (State of Charge) and SOH (State of Health).
Abnormality Warnings
The system detects irregular battery performance early, providing alerts that allow for preventive maintenance before issues become critical.
Software and Hardware Bug Detection
Leverages full lifecycle data to identify potential software or hardware issues that may affect performance or safety.
Battery Parameter Optimisation
Cloud-assisted functions collaborate with hardware to optimise on-site battery parameters, ensuring optimal performance and safety standards.
Fire-Resistant Protective Design
PowerOcean is engineered with cutting-edge fire-resistant technology to prevent and suppress potential fire hazards, ensuring the safety of users and protecting property from battery-related incidents.
Automotive-Grade Pressure Relief Valve Design
In extreme conditions, this valve efficiently releases internal pressure, preventing the battery from over-expanding and reducing the risk of fire.
Industrial-Grade Fire Prevention Module
The integrated fire suppression system reacts within 7 seconds, swiftly extinguishing detected flames to ensure the fire is neutralised before any damage occurs.
Adaptable to Extreme Weather Conditions
PowerOcean is designed to operate reliably in a wide range of weather conditions, from scorching heat to freezing temperatures, ensuring stable and efficient battery performance at all times.
IP65 Waterproof & Dustproof
Auto Heating Pad
PowerOcean's IP65-rated design offers superior protection against dust and water ingress, ensuring the battery remains fully functional even in harsh environments such as rain, dust storms, or high-humidity conditions.
Impact-Resistant Structural Design
The sturdy structural design of the PowerOcean battery pack ensures safety and functionality even in unexpected situations such as vehicle collisions, accidental drops, and impacts. From the inside out, the battery is engineered for exceptional durability.
Metallic Paint Coating
The outer shell is coated with a composite metallic finish that is resistant to wear and alcohol, ensuring no peeling or exposure of the underlying material.
High-Strength Casing
The durable casing can withstand pressures of up to 40,000N, strong enough to endure the weight of a car, ensuring the battery’s safety and longevity.
High-Elastic Silicone Pads
Each battery cell is cushioned by 1.2mm thick high-elastic silicone pads, absorbing expansion stress and protecting the cells, while also providing shock and drop resistance.
Electricity-Proof Insulation Design
The PowerOcean battery pack incorporates advanced electrical safety features to protect users from electrical hazards. Its design prevents accidental electric shocks, ensuring it is safe to use in a variety of environments, even around children and pets.
High-Voltage Insulation Design
A dual-layer high-voltage insulation system, combined with physical separation, prevents voltage leakage and ensures complete protection from electrical hazards.
No Exposed Wiring Module
This design features no exposed wiring, reducing the risk of electric shock—especially in homes with children or pets. The wireless setup allows for easy installation with simple module assembly.
Certified Durability & Warranty
International
TÜV Certified
PowerOcean is TÜV-certified (Technischer Überwachungsverein), meeting strict standards for safety, quality, and reliability.
UL9540A Compliance
PowerOcean has successfully passed the stringent UL9540A unit-level fire safety test, making it suitable for convenient indoor installations.
PAS 63100 Compliance
PowerOcean complies with PAS 63100 standards for safe and efficient energy storage in the UK, ensuring top-tier safety and performance for both indoor and outdoor applications.
United Nations
UN38.3
PowerOcean passed UN38.3 certification, verifying its safe air transportability, withstanding extreme conditions like altitude, temperature, and impact.​
UL1973
UL1973 certification guarantees PowerOcean's suitability for stationary energy storage, meeting high safety and performance standards for applications like home storage.
International
IEC62619
PowerOcean meets IEC62619 standards, focusing on the electrical and thermal safety of industrial lithium batteries.​
Recommendations
PowerOcean Single-Phase
15kWh capacity | 6kW output power
Learn More
PowerOcean Three-Phase
45kWh capacity | 12kW output power
Learn More
PowerInsight
Home energy monitor
Learn More
Learn More
Learn More
PowerInsight
Home energy monitor
Learn More
Become a Partner
Please fill out and submit the application form. Our sales team will contact you soon after review.
Product Interests*
I am a __*
* All specifications and descriptions shown may differ from the actual specification of the product. EcoFlow reserves the right to make changes and amendments to the product shown and described here at any time without prior notice of such change. All functionality, features, specifications, design and other product information displayed on this webpage including, but not limited to, components, performance, availability, and capabilities of the product are subject to change without notice. The contents and simulated images within the screen are for demonstration purposes only.
