Exploring The Pros & Cons of Available Off Grid Power Solutions
How do you like the sound of living off the grid and not at the mercy of the energy companies? Well, thanks to the various off grid power solutions that now exist, it's possible to realise this dream and achieve true energy independence. The allure of making this move has never been so strong, as UK energy prices have been particularly volatile in recent years.
Whether you're motivated by a desire to power your home in an environmentally friendly way or reduce your monthly bills, the wind, sun, and organic matter can now be used as an alternative to burning fossil fuels - a process that's known to contribute to climate change.
So, stay tuned as we examine the various off-grid power options that need to be considered. We'll examine what they are, how they work, and their pros and cons so you can make an informed decision about which type of system works for you.
Schedule Here Your Free Consultation!
Option #1 - Standard Solar Power Systems
The first of the available off grid power solutions is one that you'll probably be well aware of if you've spent time in the UK. We're talking, of course, about standard solar power systems, which are characterised by the familiar panels seen installed on roofs across the country.
These photovoltaic (PV) panels harness energy from the sun (in the form of DC electricity), which is then converted into usable AC power to run your lights, heating, devices and home appliances. When the sun is shining, these standard solar power systems provide lots of reliable, renewable electricity, with any surplus sold back to the grid via the government's Smart Export Guarantee (SEG).
No Emissions, Easy-Maintenance
The energy that comes from solar panel systems like these is clean, and it's produced in a way that creates no greenhouse gases whatsoever. Another notable benefit is the reduction in monthly costs you'll enjoy each month - something that's available for many years with little to no maintenance required on your part.
The only issue with an off grid solar power kit like this is that it only offers power when the sun is shining. At night and on cloudy days, you'll be back to relying on the grid. That means you can never be 100% sure about when you'll be able to call upon solar energy for your home's needs.
Pro: Substantial long-term cost savings and environmental benefits.
Con: High initial investment and operation are dependent on the availability of sunshine.
Option #2 - Energy Storage - Home Battery Solutions
Used as an additional aspect of a standard solar panel setup, power storage hardware like the PowerOcean Home Battery Solution can offer energy independence in the truest sense. Just like a standard system, you get to enjoy the energy from the sun when it's shining, but you also get to store electricity for use when it's not.
As such, home battery systems offer a much more reliable option for your off grid heating, lighting and general power needs. This hardware works equally well as stand alone power systems and as an option that works in tandem with grid use. An additional benefit of this type of system is that you're able to keep going when there's a grid power cut.
The best off grid solar batteries give you complete control of when you use the renewable energy that's produced - particularly when you have an energy management system to help you maximise the efficiency of your off grid electrical systems. There is an increased initial investment due to the need to buy a battery, but the various government iloans and grants available can be used to offset it.
Pro: Maximises energy independence and reliability by storing excess solar energy.
Con: Higher initial investment due to the cost of batteries.
Option #3 - Biomass Heating Systems
The next of our off grid power solutions is the biomass heating system, which is able to provide your home with heating by burning organic materials. Wood pellets, agricultural residues (straw, corn stalks, etc) and other biological matter can be used to deliver off grid heating as an alternative to fossil fuels like natural gas and oil.
A typical biomass heating system comprises a biomass boiler or stove in which the aforementioned matter is burned for space heating, water heating, and even the generation of electricity (in some advanced setups). This option is often used in rural settings where there is an abundance of biomass fuels.
As with the best off grid solar power system options, biomass heating systems also qualify for UK government incentives like the Renewable Heat Incentive (RHI). Again, there are a number of considerations you have to make before investing in a system like this, such as the initial cost and, in this case, whether you have enough fuel storage space available.
Pro: Renewable and cost-effective heating solution with potential government incentives.
Con: Initial setup cost and the need for ample fuel storage space (something many homeowners might not have).
Option #4 - Small Wind Power Systems
The last of the off grid power solutions we shine a light on in this article harnesses another of the earth's natural resources - wind! While it's not quite as widely used as solar power in the UK, small wind power hardware is increasing in popularity in areas known for consistently strong wind patterns, such as coastal areas of Wales and Scotland.
Usually made up of a wind turbine, a tower, and an inverter, this equipment spins in the wind and acts as a generator. Depending on its size and the local wind conditions, a small wind turbine can meet the needs of small to medium households.
As is the case with other types of renewable energy setups, wind turbines rely entirely on a natural resource being present - meaning that it might not be a viable choice in certain areas where there's insufficient wind. Whether you choose to invest in the necessary equipment will depend much on what part of the country you live in.
Pro: Clean, renewable energy source with potential for significant long-term savings.
Con: Dependency on local wind conditions.
Interested in the Best Off Grid Solar System Benefits?
There are various off-grid solar systems available to homeowners in the UK, but solar battery storage trumps them all in terms of universal appeal. While biomass and wind can be viable for some, they're not suitable for everyone. Solar batteries, on the other hand, can be enjoyed by many more households across Britain and beyond.
At EcoFlow, we offer the best off grid solar batteries on the market, which you can find out more about simply visiting us today at Homebattery.ecoflow.com/uk. Offering rapid charging, high energy capacity and advanced power management, our hardware can be used to create the off grid home you’re looking for.
Alternatively, to get a competitive quote based on your unique requirements, simply tap 'Order Now' for a free estimate from an EcoFlow expert. As soon as we receive your enquiry, we’ll work hard to find the perfect system for your needs.
