Choose your country or region
Italian
Swedish
Dutch
Грузия
Is Gas Cheaper Than Electricity? A Practical Guide to UK Energy Costs
Are you looking at your latest utility bill? Are you feeling the pinch? You are not alone. Across the UK, homeowners review their energy tariffs often. They want to find ways to keep costs down. A common question comes up during these talks. It is simple: Is gas cheaper than electricity?
On paper, the answer seems obvious. But looking only at the unit price does not tell the whole story. You need to understand your home energy costs fully. You must look at how efficiently you use that energy. You also need to look at hidden daily charges. Finally, you should look at the incredible new technology changing how we power our homes. Let us dive into the details. We will find out what is really costing you more.
The Unit Price vs. Efficiency Debate
Check the current Ofgem price cap for 2026. You will notice a massive difference between the two main fuel types. Gas sits around 5.9p per kWh. Grid electricity sits much higher at around 27.7p per kWh
The energy industry calls this difference the "Spark Gap." But why does it exist? Electricity unit rates are currently higher. This is because we still burn expensive gas to generate a lot of the UK's electricity. Green levies and grid maintenance costs add to the bill. This keeps the price of grid electricity high.
But the raw unit price is only half of the equation. You also need to look at the Efficiency Factor.
  • Gas Boilers: Even a brand-new gas boiler is only about 90% efficient. This means for every £1 you spend on gas, you waste 10p. The heat goes straight out of the flue. Older boilers can be as low as 60% efficient.
  • Electric Heating: Traditional electric heating is 100% efficient at the point of use. Every single watt you pay for turns into heat.
  • Heat Pumps: This is where the maths flips. A modern heat pump can be 300% to 400% efficient. It takes one unit of electrical energy. It then captures three to four units of free heat from the air outside.
Verdict: The raw unit price makes people askif gas is cheaper than electric heat. But the equation changes completely. It changes when you use modern tech. Paying a higher unit price for electricity can actually lower your bills. This happens if your system outputs three times as much energy as it takes in.
Heating Showdown: Is Gas Heat Cheaper Than Electric Heat?
Heating makes up most of a UK household's energy bill. We need to compare the two options. We must look at the specific technology keeping your radiators warm to answer: Is gas heat cheaper than electric heat?
Gas Central Heating Costs
Pros:
  • The main benefit is the lower unit cost of the fuel.
  • Gas boilers are also familiar.
  • Most UK homes already have the plumbing in place.
Cons:
  • You must pay a daily gas standing charge.
  • You pay this just to be connected to the network.
  • Boilers need costly annual servicing to remain safe.
  • Gas is a fossil fuel tied to global markets. This means prices can spike without warning.
  • Burning gas also adds to your carbon footprint.
Is Electric Heating Cheaper Than Gas?
You might wonder, is an electric heater cheaper than gas? The answer depends on how you use it. Standard electric radiators cost a lot for whole-home heating. They are effective for short bursts of spot heating in one room. But they will drain your wallet if you run them constantly.
The real game changer is the air-to-water heat pump. This tech completely flips the script on the question: Is electricity cheaper than gas for heating?
The ultimate solution for UK homes is the EcoFlow PowerHeat. The PowerHeat Air-to-Water heat pump uses electricity. It brings ambient air heat energy into your house. This achieves significantly enhanced home heating efficiency. With PowerOcean Home Battery integration, you can make the best use of clean solar power for home heating. This will slash your electricity bills.
ecoflow powerheat
Which Is More Expensive, Gas or Electricity UK for Appliances?
What about daily appliances? When looking at cooking, people often wonderif gas is cheaper than electricity. A gas hob is cheaper to run per hour based on unit rates. But gas hobs waste a massive amount of heat around the pan. Modern induction hobs are faster. They are much safer and easier to clean.
The truth is, the UK is already an electric-first society. Our lighting, TVs, and computers all run on electricity.
The hidden cost is the daily standing charge. Keeping a gas connection just for a hob costs a lot. You pay hundreds of pounds a year before you turn on a burner. Cutting the gas pipe is often the smartest move for modern households. So, which is more expensive, gas or electricity in the UK? For small appliances, sticking with gas is more expensive overall due to standing charges.
Closing the Gap: How to Make Electric Cheaper than Gas
The core problem remains. Grid electricity is expensive. The solution is self-generated electricity. You need a solar array and solar battery storage. If you generate your own power, the question changes. Asking "Is electric cheaper than gas" becomes pointless. Your "fuel" is free. However, the right setup depends entirely on your home.
ecoflow powerocean home battery
EcoFlow PowerOcean: Smart Power, Bigger Savings
EcoFlow Home Battery lets you store your own solar power to use whenever you need it. It keeps your home running during blackouts and automatically switches to battery power when grid prices are high. This is the simplest way to gain energy independence and lower your monthly bills.
Product
Key Specs
Ideal for
EcoFlow PowerOcean (Single-Phase)
LFP battery, IP65, 15-year warranty, expandable up to 15 kWh on one inverter, 6kW continuous off-grid power
Standard-sized UK homes; basic lighting/appliances use; cost-effective solar storage entry
EcoFlow PowerOcean (Three-Phase)
Expandable up to 45kWh, built-in DC-DC converter, 800V independent packs, fire/weatherproof, 10kW rated backup power (12kW for 60s)
Large modern UK homes; properties with EVs/ powerful heat pumps; high energy load households
You can also manage your power easily with the EcoFlow App. It acts as a smart brain, automatically charging your battery when electricity is cheap and switching to battery power when prices spike. This smart strategy can cut your energy bills by up to 77.6%.
Want to see how much you can save? Get a solar battery quote today. EcoFlow experts are ready to build a free, personal solution for you.
I'm not sure / Just exploring
The Future of Energy Prices in the UK
Gas prices remain very volatile. They are tied to global geopolitical events. Gas users will always face sudden price hikes.
However, the UK government is pushing for Net Zero. They might shift green levies from electricity to gas. If this happens, electricity could become much cheaper in the future.
Answering "is gas or electric cheaper" requires looking 10 years ahead. Electricity is clearly the future. Gas boilers are already being phased out in new builds. The UK energy network is going electric.
So, to summarize: Is gas cheaper than electricity? If you look strictly at the raw cost of a single unit of grid energy, yes. But in the real world, if you optimize your home with smart technology, the answer is a resounding no.
Sticking with traditional gas locks you into a cycle of rising wholesale prices, inefficient boilers, and inescapable daily standing charges. Moving to an electric setup, especially when paired with the EcoFlow PowerOcean battery systems and the highly efficient EcoFlow PowerHeat pump, offers genuine energy independence. You take control of your bills and secure your home against future price shocks.
1. Is gas cheaper than electricity per kWh in 2026?
Yes, the raw unit price of gas is lower based on the Ofgem cap. However, modern electric tech like heat pumps is 300-400% efficient. This makes electricity much cheaper to run overall.
2. Is electric heating cheaper than gas if I have solar panels?
Absolutely. If you have solar panels paired with an EcoFlow Home Battery, your electricity is essentially free once the system is paid off. This makes running an electric heat pump vastly cheaper than paying a utility company for gas
3. How much does a heat pump cost to run compared to a gas boiler?
Because a modern heat pump like the EcoFlow PowerHeat is 300-400% efficient, it uses very little power. Despite the higher unit price of electricity, the massive efficiency gain usually makes it cheaper to run annually than a standard 90% efficient gas boiler.
4. Is it worth changing from gas to electricity?
Yes, moving from gas to electric is a smart long-term investment. By switching to an electric heat pump and induction cooking, you can improve your home's safety, lower your carbon footprint, and protect yourself from volatile global gas market spikes.
5. Can I remove gas from my house?
Yes. If you install an electric heat pump for heating and hot water, and switch to an electric induction hob for cooking, you no longer need gas. You can then contact your supplier to cap the meter, saving you hundreds of pounds in daily standing charges.
Home Energy Savings
