Long-Lasting Performance with Multi-layered Protection
Power Outages Can Strike Anytime and Last Long
Extreme weather and an aging power grid are causing longer, more frequent outages across the U.S. Texas saw 1,300 outages in 2024, and California’s blackouts hit over 700,000 people in 2025*. In some areas, power can be out for up to 112 hours—are you prepared for an extended outage?
* All data sourced from the U.S. Energy Information Administration.
Energy Costs Continue to Rise
Electricity prices keep climbing—up 2.67% annually over 25 years, and a sharp 4.8% yearly jump since 2019. In high-rate states like Hawaii and California, summer bills can hit $700–800. As rates soar, your wallet could be next. How much longer can you afford to rely solely on grid energy?
Unlimited Whole-Home Backup with Solar Power
Tap into the full potential of your rooftop solar with OCEAN Pro’s 40kW solar-powered backup. Enjoy seamless 24kW continuous output—enough to run your entire home, including two 5-ton HVAC systems. The system is even compatible with gas generators for an added layer of worry-free, round-the-clock energy security.
With 40kW solar input, EcoFlow OCEAN Pro utilizes more rooftop solar to store extra energy.
Start with 10kWh per battery and scale up to 80kWh, tailoring your backup to fit your home's needs.
At the core of EcoFlow OCEAN Pro is its 24kW continuous output and 205LRA surge power, delivering enough power to run your entire home without compromise.
40kW Max
Solar Input
10kWh-80kWh
Scalable Battery Capacity
24kW Continuous
Output
Solar Power Your Home, Slash Your Energy Bills
Harness up to 40kW of free solar energy with OCEAN Pro’s scalable capacity. Maximize savings with intelligent insights tailored to your usage. Plus, join a Virtual Power Plant (VPP) [1] to earn by selling excess energy back to the grid—turning your solar power into real value.
Switch to AI Saving Mode with one click and let smart energy management cut your bills automatically
Save more with intelligent energy schedule that adapts to your solar power, tarriff, and consumption patterns.
Prioritize your home’s power supply with the EcoFlow App to save on bills while keeping what matters powered [2].
Maximize Savings: Solar Incentives & Policies
Solar incentives and policies vary by state, and electricity rates continue to rise nationwide. This home solar energy system helps protect you from higher bills and an unpredictable grid.
OCEAN Pro is designed to deliver long-term savings and unlimited backup power. Order now to start lowering your energy costs.
CA
Net Energy Metering (NEM) 3.0 programme
Self-Generation Incentive Program (SGIP)
TX
Property tax exemption for solar energy systems
Local solar tax credits and incentives for Texas
FL
Property Tax Abatement for Renewable Energy
Florida Net Metering
CA
TX
FL
Sustainable Home Solar Power with Lasting Quality
Reliable in heat or cold
Fire-prevention module
Flood-resistant
15 year warranty
Engineered to perform in temperatures from -4°F to 140°F, OCEAN Pro's LFP battery pack features an advanced Battery Management System that continuously monitors every cell and connection point for overheating risks. Its 360° Aerogel Insulation helps regulate battery temperature, preventing thermal stress even during peak load or harsh weather.
Flood-resistant
15 year warranty
How EcoFlow OCEAN Pro solar power solution is installed in your home
Solar battery installation process after finishing payment:
1. System Sizing & Design
Determine energy needs and choose appropriate battery size.
2. Permit Acquisition
Obtain necessary permits and ensure compliance.
3. Site Preparation
Clear obstructions and ensure site safety.
4. Installation
Install solar panels, inverter, and battery storage.
5. Testing & Activation
Conduct tests and activate the system.
6. Registration & Maintenance
Register for incentives, warranty, and schedule maintenance.
Get Tailored Home Solar Energy Solutions from an Expert
Free Consultation
1-1 expert free consultation
Certified Installer Network
Local solar installers with installation training and certification to ensure top-quality service.
100% Process Visibility
Real-time project tracking on EcoFlow App
Free Consultation
EcoFlow Endorsed by
Get a Free Quote for Your Home Solar Power System
FAQs on Home Solar Energy System
How much power can I generate with solar?
A typical home solar power system generates 350–850kWh monthly, depending on sunlight and system size. Pairing with OCEAN Pro maximizes energy capture with smart battery storage. [Explore OCEAN Pro's capabilities →]
What is a solar battery (solar + storage)?
A solar battery, such as OCEAN Pro, stores excess energy for use at night or during outages. It turns your solar panels into a 24/7 power source.
Can I install OCEAN Pro myself?
No—a certified installer is required to ensure safety and efficiency. We partner with trusted professionals nationwide. [Find an OCEAN Pro installer near you →]
How many OCEAN Pro batteries do I need?
The number of solar batteries needed to power your home depends on your energy use. Most homes need one or two units. EcoFlow offers smart solar power for your home solutions, helping you easily size the right solar energy system for reliable, efficient power. Get a free, personalized recommendation from an EcoFlow energy expert. [Calculate your needs →]
How much can I save with OCEAN Pro?
Users can save 40%+ on bills, and can even reduce costs down to nearly $0 by optimizing stored solar energy for home. [See OCEAN Pro savings examples →]
Are there additional financial incentives to purchase an OCEAN Pro?
How big of a solar system do I need to run my house?
Most homes require a solar system between 5kW and 20kW to cover their electricity needs. The exact size depends on energy consumption and local sunlight. EcoFlow's solar energy for home setups is flexible and scalable, allowing you to customize the perfect solar system to fully power your home with clean energy.
[1] The ability to join a Virtual Power Plant (VPP) varies by region, utility company, and availability.
