Choose your country or region
Solar Energy Ecosystem
  • Overview
EcoFlow Intelligent Home Energy Ecosystem
Experience smarter, cleaner, more resilient power that protects your family, cuts your energy costs, and promotes a more sustainable future.
Welcome to Your EcoFlow-Powered Home
The EcoFlow Home Energy ecosystem brings solar power, battery storage, smart circuit control, EV charging, and the EcoFlow App together into one simple, intelligent system you can see, understand, and intuitively control.
Unlimited Whole-Home Backup
All-in-One Energy Management
Turn Sunlight Into Savings & Earnings
Drive on Solar Power
With the EcoFlow OCEAN Pro Solar Battery System, your home stays powered through anything—from routine outages to extreme weather.
How Your Home Stays Powered
Your system uses solar, the grid, EcoFlow products, third-party generators, and even EV vehicle-to-load (V2L) to ensure you always have reliable backup energy.
Whole-Home Power, No Limits
With 24 kW of continuous output, the EcoFlow Home Energy ecosystem can deliver enough power to run the major appliances throughout your entire home.
Powerful enough to run your whole home
Even with two 5-ton HVAC systems running
One Tap, Full Control
An Award-Winning Experience
Winner of the 2025 UX Design Award, the EcoFlow App brings simplicity to home energy control.
With just one tap, you can check power status, switch modes, or manage any circuit.
UX Design Awards
Customized Circuit-Level Control
See Every Circuit. Set Your Priorities in Advance.
With the Smart Electrical Panel, every circuit in your home becomes visible and adjustable. You can ensure essential circuits stay running longer, reduce usage in specific rooms, or even give your EV charging the top priority.
Your Home Learns and Adapts
With PowerInsight 2, you can see the real-time status of your home's energy usage. We're also deepening our integration with an expanded range of smart home devices, so your EcoFlow ecosystem is always growing, providing a more comfortable and intelligent living experience for your family.*
Declaration: Supported Thermostats: Google Nest Learning Thermostat, Ecobee Smart Thermostat Protocol: Matter integration via EcoFlow PowerInsight 2
Turn Sunlight Into Savings and Earnings
Solar Power
40 kWh/day
Your Bill
$100/day
Savings from the Sun
With up to 40kW of solar input, the EcoFlow Home Energy Ecosystem lets your home run on solar-generated clean energy throughout the day. Solar power flows into your appliances first, and any extra energy is stored in your batteries to use later.
Solar Self-Consumption
Use the power you generate first Daytime solar runs your home, and any extra energy charges your batteries.
Smart TOU Savings
Use energy when it’s cheapest When rates drop at night, the system automatically charges your batteries. When prices rise during the day, it switches to stored solar power to cut your bills up to $150-$200 in potential monthly savings.*
Solar-First Charging
Use sunlight first to charge your EV, saving more with every mile
Scheduled TOU Charging
Set your car to charge automatically during low-rate hours under TOU plans
Fast & Custom Power Charging
Go up to 11.5 kW for a quick top-up (compatible with J1772 and NACS connectors).
