Choose your country or region
Italian
Swedish
Dutch
Грузия
How Much Does It Cost to Rewire a House in the UK? 2026 Price Guide
Whether it’s a fixer-upper project or an old family home that’s started showing its age, a house rewire is a massive job that you really can’t ignore. In 2026, with EV chargers and heat pumps becoming the norm, your old wiring simply isn’t cut out for the job anymore. In this guide, we’ll break down the latest 2026 costs, explore the factors that shift the price, and share some savvy ways to save while preparing your home for a more energy-efficient future.
Why Rewiring May Be Necessary
Before we talk numbers, rewiring is making sure your house doesn’t become a safety hazard the moment you plug in a hair dryer.
1. Old or Faulty Wiring
Many older UK homes still hide wiring that dates back to the 1960s or even earlier. Once electricians lift the floorboards or open the walls, it’s not unusual to find black rubber cables or outdated fuse boxes that no longer meet modern safety standards. If you find lead-sheathed or black rubber cables (the pre-1960s stuff), they’ve long since reached their expiry date. If your fuse box still uses that fiddly old fuse wire instead of modern circuit breakers, it’s a massive red flag.
2. Electrical Safety and Fire Risks
Faulty electrics are one of the biggest causes of house fires in the UK. Faulty insulation or loose connections can quietly arc behind the walls for months before anyone notices a problem.
A modern rewire replaces these ageing cables with safer wiring systems and RCD protection that automatically cuts power within milliseconds if a fault occurs.—the stuff that cuts the power in milliseconds if something goes wrong. According to Electrical Safety First, electrical faults are responsible for over 13,000 house fires in the UK every year.
3. Higher Modern Power Demands
Now? We’re charging EVs in the drive, running high-spec gaming rigs, installing heat pumps, and managing home battery storage systems to beat peak energy tariffs. Most old UK systems just weren’t built for this “always-on” demand. A 2026 rewire ensures your home meets the latest BS 7671 (18th/19th Edition) wiring regulations, providing the robust infrastructure needed for a carbon-neutral lifestyle.
4. Renovations and Home Upgrades
If you’re already planning a posh new kitchen or a bathroom refit, Building Regs (Part P) will often force your hand to upgrade the electrics anyway. Honestly, it’s much cheaper to bite the bullet and rewire the whole house while the floorboards are already up, rather than doing it bit-by-bit.
Factors That Influence Rewiring Costs
No two British homes are the same, and neither are their rewiring quotes. Several key variables will determine whether your bill is closer to the “budget” or “premium” end of the scale.
1. Size and Layout of the Property
It goes without saying that a sprawling five-bedroom detached house in the Cotswolds will cost more to rewire than a one-bedroom flat in Manchester. More rooms mean more “points” (sockets and lights), more cable, and more time for the sparky to crawl through tight spaces.
2. Type of Wiring System Used
Standard twin-and-earth cabling is the norm, but the complexity of your circuit design matters. If you’re adding dedicated circuits for high-draw appliances or preparing for a solar-ready home, the initial infrastructure requires more planning and materials.
3. Labour and Installation Complexity
Labour is your biggest expense. If your home has solid brick walls (common in older UK builds), “chasing” channels for wires is a dusty, time-consuming job. Conversely, if you have suspended timber floors and easy attic access, the job goes much faster. Also, expect to pay a “London premium” if you’re living within the M25. This regional price gap is part of a larger trend in why UK electricity is so expensive compared to other nations.
4. Materials and Components Quality
While you shouldn’t skimp on the basics, you can choose between standard white plastic sockets or premium brushed steel finishes. Higher-end consumer units with individual RCBOs (Residual Current Breaker with Overcurrent) also add to the hardware cost but offer better circuit independence.
5. Additional Work and Upgrades
A rewire is rarely just a rewire. You might need to replaster walls after the cables are buried, or perhaps you want to add outdoor security lighting. These extras can quickly add a few hundred pounds to the final tally.
Typical Cost Ranges for House Rewiring
So, what should you actually budget? Industry data from Checkatrade and MyBuilder suggests that the average cost of a full house rewire in the UK currently ranges between £5,000 and £8,000 for a typical three-bedroom property.
Based on 2026 market rates, here’s a rough guide to what you can expect to pay for a full rewire, including a new consumer unit and certification.
Property TypeEstimated Cost (2026)Est. Duration
1-2 Bed Flat£3,200 – £4,8003–5 Days
3 Bed Semi-Detached£5,000 – £8,0005–7 Days
4-5 Bed Detached£8,500 – £12,000+7–10 Days
Note: Prices are highly regional. While the figures above reflect national averages, expect a “London & South East Premium” of 20%–30%. Conversely, projects in the North of England or Scotland may sit at the lower end of these scales. In 2026, due to inflation and rising material costs, £6,500 is often considered the starting point for a standard-spec 3-bed semi-detached home.
1. Average Rewiring Cost Per Square Metre
Some electricians estimate rewiring costs based on floor area instead of property type.
In most parts of the UK, the price usually works out at £60–£95 per m² for a full rewire. Properties with solid brick walls or difficult access to floors and loft spaces often cost more because the job takes longer.
For example, a 90–100 m² three-bedroom semi-detached home may end up costing roughly £5,400–£9,500 to rewire.
2. Cost for Flats and Terraced Houses
For smaller homes, the price is naturally lower. Rewiring a 1–2 bedroom flat usually costs between £3,200 and £4,800 across most parts of the UK.
A mid-terrace house normally comes in at £3,800 to £5,800. The compact layout often keeps labour time down, although older plasterwork or solid brick walls can make the job slightly more involved.
3. Cost for Semi-Detached and Detached Houses
A standard 3-bedroom semi-detached home — one of the most common property types in the UK — typically costs between £5,000 and £8,000 to fully rewire, depending on location and accessibility. According to Checkatrade, the national average for a full house rewire is around £6,500. If you’re looking at a 4-5 bedroom detached property, the budget can easily scale from £8,500 to £12,000+ due to the sheer volume of wiring and points required.
4. Additional Costs for Loft Conversions and Extensions
Adding a loft conversion usually adds about £1,000 to £2,000 to a rewire project. Since these areas often require their own sub-circuits and fire-rated downlights, it’s best to factor this in early. If you’re planning to use that extra space for energy storage, check whether you can install a solar battery in a loft to ensure your structural and electrical plans align.
5. Hidden Costs and Unexpected Charges
Always set aside a 10% contingency fund. If your property was built between 1930 and 1980, your electrician might discover asbestos in floor tiles or textured coatings (like Artex) while pulling up boards. Professional asbestos testing can add £200–£500 to your budget, but it is a vital safety step.
EcoFlow Ocean2 home battery storage system
Is a Partial Rewire Enough or a False Economy?
You don’t always need to rip out every wire in the house. If your consumer unit is modern but a specific area is struggling, a partial rewire might be the smarter, more surgical fix.
1. Typical Costs for Focused Upgrades:
  • The Kitchen (£1,200–£2,500): Often the most expensive “partial” job because of the heavy load from ovens, induction hobs, and multiple appliances.
  • Bathroom Circuits (£600–£1,200): Usually involves installing dedicated zones for electric showers or specialized IP-rated lighting.
  • Lighting Loops (£800–£1,500): A common choice for older homes where the original lighting has no earth wire—a major safety red flag.
2. The Reality Check
While a partial rewire is easier on the wallet today, it can be a bit of a “Band-Aid” fix. If your home’s core wiring is hitting the 40-year mark, you’re often better off biting the bullet and doing the full job. Why? Because paying an electrician for three separate “partial” visits over five years will always cost more than one big, messy, but complete overhaul.
How Long Does It Take to Rewire a House?
Most full house rewires take between 5 and 10 days depending on the size of the property and whether the home is occupied during the work. Typical timelines include:
  • 1–2 bedroom flat: 3–5 days
  • 3-bedroom house: 5–7 days
  • 4–5 bedroom house: 7–10 days
Additional time may be required for plastering repairs and final certification.
Practical Tips to Save More on Rewiring Costs
While a rewire is a big outlay, there are ways to work smarter and save money in the long run by making your home future-proof.
1. Plan Electrical Layout With Future Energy Needs
During a rewire, the complexity of cabling increases if you’re trying to patch in solar panels and batteries later. You can simplify this by choosing an all-in-one solution like the EcoFlow OCEAN 2. Its integrated design and compact wiring mean less hassle for your electrician and a tidier installation. Plus, with multiple MPPT channels, it can manage different solar arrays independently, helping you balance your home’s load and slash those monthly energy bills from day one.
2. Integrate Smart Energy Monitoring During Rewiring
Once the rewire is done, the sheer number of new gadgets can make your electricity bill creep up. Without a clear view of where the power is going, it’s hard to save. Installing a smart energy monitoring system such as the EcoFlow PowerInsight 2 during your project can provide a central “brain” for tracking electricity usage. By looking at your history, you can schedule heavy appliances to run when your battery is full or when off-peak rates are lowest, ensuring your newly rewired home is as efficient as it is safe.
3. Combine Rewiring With Other Home Improvements
The single most expensive way to rewire is to do it in a house that’s already finished and furnished. The real savings happen when you combine the electrical work with a major renovation. If you’re already ripping up carpets or getting the decorators in, your electrician can move twice as fast without having to “baby” your flooring or furniture. It’s messy work—do it while the house is a shell and you’ll save a fortune in labor hours.
4. Choose Cost-Effective Materials and Fixtures
You don’t need high-end brushed brass or matte black sockets in every dusty corner of the house. One of the easiest ways to slash your materials bill is to be strategic about where you splurge.
Invest in the premium, decorative switches for your hallway, lounge, and kitchen—the places you and your guests will actually see and touch every day. For everywhere else—think utility rooms, inside storage cupboards, or the sockets hidden behind the TV and fridge—stick to standard, reliable white plastic units. It’s a simple “mix and match” approach that can easily shave hundreds of pounds off your total cost without compromising the look of your home.
5. Plan for Energy Efficiency Upgrades
The biggest mistake homeowners make is closing up the walls too soon. While the floorboards are up, think two steps ahead:
  • EV Readiness: Even if you aren’t driving an electric car yet, have the electrician run the heavy-duty cabling for a charger now. Retrofitting this in two years will cost triple; doing it now is almost negligible.
  • Smart Tech & Efficiency: This is the perfect window to install smart thermostats or add extra insulation. Once the plastering is done, the “cheap” window for these upgrades closes forever.
EcoFlow PowerInsight 2 monitor
I'm not sure / Just exploring
A full house rewire is undeniably a massive, messy undertaking—there’s no way around the dust and the disruption. But once the floorboards are back down, you aren’t just paying for new copper in the walls; you’re buying decades of safety and a home that can actually handle modern life.
If you’re sitting on a quote for £4,500 to £8,000, remember that the cheapest bid isn’t always the best one. Look for an electrician who understands the importance of a centralized home energy management system to help you control your consumption—whether that’s a smart home setup or an EV charger—so you only have to do this once. It’s an investment that pays off every time you plug in a device without tripping a breaker, and it’s a major selling point if you ever decide to move on.
1. How much would it cost to rewire a 3 bed house in the UK?
A full rewire for a typical 3-bedroom house in the UK usually costs between £4,500 and £8,000, depending on your location and the complexity of the job. This typically includes a new consumer unit, all new cabling, and the final safety certification.
2. How to tell if a house needs rewiring?
You can tell a house needs rewiring if you see outdated components like a wooden-backed fuse box, round pin sockets, or cables covered in black rubber or lead. Persistent issues like frequently tripping breakers, flickering lights, or a slight “burning” smell near outlets are also major red flags.
3. Can I live in my house while it's being rewired?
Yes, you can live in your house during a rewire, but it is highly disruptive, dusty, and often involves having the power turned off during the day. Most electricians recommend vacating the property or at least moving room-to-room if a full exit isn’t possible.
4. Is it worth rewiring an old house?
In most cases, yes. Rewiring an older property improves safety, supports modern appliances, and can even increase resale value. Some insurers and mortgage lenders may also require updated electrical systems before approving coverage.
5. Can I get a government grant for rewire my house in the UK?
There are no specific grants solely for rewiring, but you may qualify for help through the Warm Homes Plan or ECO4 scheme if the electrical work is required to support energy-efficiency upgrades like heat pumps or solar panels. These schemes are generally targeted at low-income households or those in inefficient properties.
Home Energy Management
