Choose your country or region
Heat Pump Repair Guide: Common Problems and How To Fix Them
Is your heat pump acting up just when you need it most? This practical heat pump repair guide walks you through common issues and fixes, helping you determine what you can safely handle yourself and when it’s time to call the pros. That way, you can keep your home’s heating system running efficiently.
Why Maintenance and Heat Pump Repair Matter
Regular maintenance and timely heat pump repairs are essential to keep your air source heat pump (ASHP) running efficiently, especially systems like EcoFlow PowerHeat, which are designed for optimal year-round performance.
Even minor problems, such as clogged filters or low refrigerant levels, can reduce efficiency (SCOP), leading to increased energy consumption or long-term damage. Not all homeowners are aware that ignoring these signs can shorten a system’s lifespan.
Staying on top of routine care and addressing problems early protects your investment, keeps your home comfortable and reduces your carbon footprint. A well-maintained heat pump is quieter, greener and more cost-effective to operate.
Common Symptoms Homeowners Notice
If your heat pump system is experiencing any of these symptoms, you might have to look for a heat pump repair service near you:
  • No heat or lukewarm radiators - The system might have a poor ability to reach the set temperatures during colder months.
  • Short cycling or constant running - This is usually an indication of a defect in the thermostat, sensors or refrigerant amount.
  • Outdoor unit iced up - Some frost is normal, but heavy ice build-up could mean the defrost cycle isn’t working properly.
  • High electricity bills – A sudden spike may indicate that your heat pump is working harder than it should.
  • Unusual noises or vibrations – Rattling, humming, or buzzing could mean loose parts or wear and tear.
  • Error codes on the controller – These provide helpful clues about what’s going wrong.
DIY Checks Before Calling a Heat Pump Repair Service
Before booking heat pump repair servicing, there are simple checks you can safely try at home. These quick steps can fix the problem or assist the repair engineer in diagnosing it faster.
  • Thermostat and mode controls - You should make sure that your system has been adjusted to heating and the temperature level is high enough to activate the heat pump.
  • Breakers and isolation switches - Check that your fuse box and isolation valves are not off. Resetting them can sometimes bring things back online.
  • Clean filters and outdoor unit - Dirty filters slow down the flow of air, and leaves or snow surrounding the outdoor unit may prevent its operation. A quick tidy-up helps.
  • Heating curve and DHW schedule – Review these in your settings, especially if outdoor temperatures have recently dropped. EcoFlow’s AI-powered HEMS can help monitor and optimise this automatically. EcoFlow PowerInsight also helps monitor your heat pump system performance, making it easier to catch issues early and share data with your engineer.
  • Bleed radiators or ground loops - Air in the system can reduce heat output. Bleeding radiators is a simple DIY job with big results
These easy checks might save you a call or make your heat pump repair visit quicker and more effective.
Heat Pump Servicing: Problems That Require a Professional
Some heat pump issues are best left to the experts. While basic checks can solve minor problems, certain system malfunctions need professional attention to ensure safe and effective heat pump repair.
In case of the following, then you should call in a qualified engineer:
  • Constant icing or defrost safety cycle failure - In case your outdoor unit is continuously icing over and is not properly defrosting, it might be a sensor or control issue.
  • Leaks or pressure defects of refrigerants - It involves an F-gas certified technician, and it may affect the effectiveness and safety.
  • Repeated fault codes or sensor failures - When the error persists, then there is a problem in the system that requires diagnostic tools.
  • Persistent undercycle or under-performance - This may be due to a system design issue or sizing problem, and an expert examination is required.
Frequent Root Causes of Heat Pump Issues
The symptoms vary, but problems may stem from these root causes:
  • Airflow limitation - Blocked airflow from leaves, snow, or fencing around the outdoor unit can lower efficiency and cause faults.
  • Wrong heating curve or flow temperature - Turning on the wrong setting can lead to lukewarm radiators or high bills.
  • Undersized radiators or poor hydronic balancing - Radiators that are unable to produce low flow temperatures can lead to cold rooms and overwork the system.
  • Air or sludge in the system - Dirty water or trapped air will cause cold spots as well as noise and permanent damage unless filtered or treated.
  • Pipework insulation or incompatible emitters - Heat loss through pipes or using the wrong type of emitters reduces system efficiency.
These issues sound familiar? Perhaps it is high time to schedule a professional heat pump repair and system check-up.
ecoflow powerinsight
Understanding Icing and Defrost Cycles
During colder months, a small amount of frost forming on heat pumps is normal. These systems are designed to defrost automatically and proceed to operate effectively.
But when you observe thick ice build-up that does not melt, something may be wrong.
Common causes include:
  • Blocked airflow
  • Faulty sensors
  • Defrost cycle failure
As a homeowner, you can help by clearing leaves, snow, or debris from around the unit. If icing continues, it’s time to call a professional to check sensors, refrigerant levels, and system controls as part of a proper heat pump repair.
What’s Included in a Professional Service
A professional heat pump repair service covers a full health check-up for your system. Done annually, it helps keep your heat pump running efficiently, safely, and for as long as possible.
Here’s what a typical service includes:
  • Electrical safety checks – All wiring and connections are tested to ensure safe, reliable operation.
  • Coil and filter cleaning – Dirty filters and coils reduce efficiency, so these are thoroughly cleaned or replaced.
  • Pump and fan inspections – Moving parts are checked for wear, noise or signs of failure.
  • Refrigerant pressure and leak testing – Low refrigerant can cause performance issues; leaks are identified and fixed by F-gas certified engineers.
  • Ground source systems – Antifreeze levels and loop pressure are tested to ensure stable operation in colder conditions.
Regular servicing not only reduces the risk of costly heat pump repairs but also helps keep your system efficient and eco-friendly.
I'm not sure / Just exploring
Preventing Future Heat Pump Repairs
Preventing future heat pump repairs starts with good habits and regular care. Taking simple steps now can save you time, money and stress later on.
Take note of the following to keep your system running smoothly:
  • Schedule annual servicing – A professional check helps catch small issues before they become big problems.
  • Keep the outdoor unit clear – Remove leaves, snow, or debris to ensure proper airflow and prevent icing.
  • Optimise the heating curve – Avoid running your heat pump like a traditional boiler to maintain efficiency and comfort.
  • Monitor performance – Using heat and electric metres helps track your system’s SPF, letting you spot problems early.
  • Log errors and services – Keeping a simple record ensures consistency and helps engineers diagnose issues faster.
Pairing your heat pump with EcoFlow PowerGlow, a smart immersion heater, can further boost efficiency, giving your home reliable warmth while reducing energy consumption and wear on your system.
Observe Regular Servicing for Your Heat Pump Systems
Regular servicing keeps your heat pump running smoothly, efficiently and safely. While many minor issues, like blocked filters or incorrect settings, can be solved with simple at-home checks, some problems run deeper.
If your system shows signs of persistent faults, unusual noise, or reduced performance, it is best to call a qualified technician. Issues involving refrigerant or electrical components should always be handled by professionals to avoid further damage or safety risks. You can get a consultation service to check your overall heating system as well.
Routine service appointments catch small problems early, extend the life of your overall home energy ecosystem, and ensure it continues to run at peak efficiency, saving you stress, energy, and money in the long term.
1. How often should I service my heat pump?
Heat pumps are generally easy to maintain. It’s best to service your heat pump once or twice a year. Regular checks keep it running efficiently, help spot small issues early and reduce the risk of unexpected breakdowns in colder months.
2. What is the most common problem with heat pumps?
Heat pumps not turning on is one of the top common issues. If your heat pump does not run, check the thermostat settings, circuit breaker and air filter first. If it still won’t start, call a professional to avoid further damage or safety risks.
3. Can I fix my heat pump myself?
You can try simple checks like clearing debris, cleaning filters, or checking your settings. However, for anything involving refrigerant, electrical parts or error codes, it’s safest to call a qualified repair technician.
Home Energy Management
