Choose your country or region
EcoFlow Home Battery Storage UK Solution
Home Battery Storage UK Solution with PowerOcean
Solar battery Storage
Create a smart solar system with storage for your home with EcoFlow products – for maximum energy efficiency, lower electricity costs, and greater independence thanks to intelligent control, modular expandability, and dynamic tariffs.
Get a free consultation now
Why choose a solar system with storage from EcoFlow?​
EcoFlow offers a comprehensive range of solar battery storage systems that reliably deliver energy, even when the sun isn't shining. With EcoFlow's smart solar systems with storage, you can significantly increase your home's energy efficiency. These systems not only help reduce your electricity bills but also minimise your carbon footprint. Discover how EcoFlow helps make your home more energy-efficient and sustainable:
Safety and Reliability Home Battery
EcoFlow storage systems with lithium iron phosphate (LFP) chemistry, comprehensive BMS battery protection, and an integrated active aerosol fire protection module for additional safety.
Flexible and expandable battery systems
Flexible and expandable systems
EcoFlow offers scalable, modular storage solutions for home and on the go that store and use energy flexibly, tailored to customer needs.
Intelligent energy for your home
With EcoFlow, you configure your solar system to efficiently store and use solar energy, secure your energy supply, and reduce your electricity costs.
Sustainably energy independent with EcoFlow Home Battery
With solar storage systems, you can increase your self-consumption, reduce grid dependency, and lower your carbon footprint through more efficient use of solar energy in your home.
Our solar systems with storage - product portfolio​
EcoFlow PowerOcean is a powerful series of intelligent solar battery storage systems that allow you to optimise the use of solar energy in your home. Whether you have high or low energy needs, require a single-phase or three-phase power supply, or are looking to retrofit an existing PV system, the PowerOcean series has you covered.
PowerOcean (1-phase)
PowerOcean (3-phase)
For homeowners with energy needs for the entire household
Energy supply
3-phase system
Output power
6 to 12 kW
Storage/backup capacity
5 to 45 kWh
Learn More
Learn more about our safety technologies and battery innovations
Learn More
Longer cycle life Battery
Longer cycle life
Safe and stable LFP battery chemistry
Comprehensive BMS battery protection
Protection against overvoltage, undervoltage, and more
Integrated active aerosol fire protection module
Increased safety
Easy battery capacity expansion with PowerOcean
Stackable modular design, integrated optimiser for parallel expansion
Weather and shock resistance
IP65 protection against dust and water 40,000 N impact resistance
Everything in view with the EcoFlow app​
With EcoFlow PowerOcean, you can set up a smart solar energy storage system for your home and customise it to your needs. Through the EcoFlow app or the web portal, you have instant access to real-time and historical solar and battery statistics, as well as features such as dynamic tariffs, TOU, solar surplus allocation, and backup reserve.
Dynamic Tariffs & TOU
Use dynamic tariffs to schedule automation tasks and optimise energy usage.
Dynamic Tariffs & TOU with EcoFlow PowerOcean
Use Solar Surpluses
Plan controllable loads to efficiently utilise excess solar energy.
Use Solar Surpluses with EcoFlow PowerOcean
Backup Reserve
Determine the percentage of your backup reserve to be optimally prepared for power outages.
Learn More
Backup Reserve with EcoFlow PowerOcean
We will be happy to advise you
Customised Offer
Our team will provide you with comprehensive advice on all aspects of solar systems with storage solutions. From initial planning and component selection to installation and maintenance, you're in good hands with EcoFlow.
Learn More
Our Customers Share
Learn how our solar systems with storage solutions have changed our customers' lives. Each case study tells a unique story—from the initial idea to installation, daily use, and the tangible benefits.
Learn More
Solar Calculator
Use our solar calculator to calculate how much you can save with an EcoFlow solar system with storage. Enter your data and you'll receive an initial estimate of your individual savings potential in just a few seconds.
Frequently asked questions about EcoFlow solar systems with storage
What do I need to consider when investing in a solar energy system with storage?
There are many factors to consider when purchasing a solar energy system. These include the location of the home, the roof pitch, local regulations, the energy needs of the home, the size of the system, the expected return on your investment, the choice of solar panels, and much more. A reliable solar installer will guide you through the entire process, from planning to installation. Schedule a free consultation with our EcoFlow consultants today.
* All specifications and descriptions shown may differ from the actual specification of the product. EcoFlow reserves the right to make changes and amendments to the product shown and described here at any time without prior notice of such change. All functionality, features, specifications, design and other product information displayed on this webpage including, but not limited to, components, performance, availability, and capabilities of the product are subject to change without notice. The contents and simulated images within the screen are for demonstration purposes only.
